lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
sander11
Oct 17, 2009Aspirant
I think the permissions issue is the failure notice from not being able to read the ini file. I don't remember exactly the steps I took, its a little too frustrating to recall. :x
I do remember manually creating the path for the ini file and then manually copying over an ini file I had from my old crashed system and modifying it for the readynas. I would google a sample ini or install it on your main system and copy over the ini file from there.
Other than that, I used the latest sabnzbd at the time 0.4.11 and it works, but for some reason can't generate the api key so I disable it.
