lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
sander11
Oct 17, 2009Aspirant
I have a pro, but only 1gb of ram, and its as fast as my bandwidth allows which is about the same speed you get on your PC.
Sounds like it could be the CPU or a bandwidth cap in your config.
