lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
tjeerdoo
Nov 09, 2009Aspirant
I try to setup SABnzbd using the "howto" from
http://www.thibernet.com/442-install-sabnzbd-on-a-readynas-duo/comment-page-1#comment-12516
But when I try to launch the service with the following command ;
/usr/local/bin/python2.5 /root/src/SABnzbd-0.4.6/SABnzbd.py
I get this ;
It “hangs” on the last line…when i try connecting to the box with firefox no page displays…
When I try to launch it using
I get no errors what so ever, but i’m still not able to launch it in a webpage…any ideas on what i’m doing wrong ?
The only error I see is "2009-11-09 16:07:51,968::INFO::ionice binary… NOT found!"
but I doubt that is the problem....any thoughts on this ?
I get this ;
2009-11-09 16:07:51,682::INFO::——————————–
2009-11-09 16:07:51,692::INFO::SABnzbd.py-0.4.6 (rev=1888)
2009-11-09 16:07:51,702::INFO::Platform = posix
2009-11-09 16:07:51,710::INFO::Python-version = 2.5.2 (r252:60911, Nov 9 2009, 14:26:45)
[GCC 3.3.5 (Debian 1:3.3.5-13)]
2009-11-09 16:07:51,778::INFO::[sabnzbd] Loading data for rss_data.sab from /root/.sabnzbd/cache/rss_data.sab
2009-11-09 16:07:51,837::INFO::[sabnzbd] Loading data for bytes7.sab from /root/.sabnzbd/cache/bytes7.sab
2009-11-09 16:07:51,848::INFO::[sabnzbd] Loading data for queue7.sab from /root/.sabnzbd/cache/queue7.sab
2009-11-09 16:07:51,867::WARNING::[downloader] No active primary servers defined, will not download!
2009-11-09 16:07:51,886::INFO::All processes started
2009-11-09 16:07:51,915::INFO::_yenc module… found!
2009-11-09 16:07:51,924::INFO::celementtree module… found!
2009-11-09 16:07:51,933::INFO::par2 binary… found (/usr/bin/par2)
2009-11-09 16:07:51,942::INFO::unrar binary… found (/usr/bin/unrar)
2009-11-09 16:07:51,951::INFO::unzip binary… found (/usr/bin/unzip)
2009-11-09 16:07:51,959::INFO::nice binary… found (/usr/bin/nice)
2009-11-09 16:07:51,977::INFO::pyOpenSSL… found (True)
2009-11-09 16:07:51,997::INFO::Web dir is /root/src/SABnzbd-0.4.6/interfaces/Default
2009-11-09 16:07:52,101::INFO::Starting SABnzbd.py-0.4.6
2009-11-09 16:07:52,114::INFO::[nzbqueue] Saving queue
2009-11-09 16:07:52,128::INFO::[sabnzbd] Saving data for queue7.sab in /root/.sabnzbd/cache/queue7.sab
2009-11-09 16:07:52,140::INFO::[sabnzbd] Saving data for bytes7.sab in /root/.sabnzbd/cache/bytes7.sab
2009-11-09 16:07:52,151::INFO::[sabnzbd] Saving data for rss_data.sab in /root/.sabnzbd/cache/rss_data.sab
2009-11-09 16:07:52,181::INFO::[sabnzbd.misc] URLGrabber starting up
2009-11-09 16:07:52,199::INFO::Starting web-interface on localhost:8080
09/Nov/2009:16:07:52 CONFIG INFO Server parameters:
09/Nov/2009:16:07:52 CONFIG INFO server.environment: production
09/Nov/2009:16:07:52 CONFIG INFO server.log_to_screen: True
09/Nov/2009:16:07:52 CONFIG INFO server.log_file: /root/.sabnzbd/logs/cherrypy.log
09/Nov/2009:16:07:52 CONFIG INFO server.log_tracebacks: True
09/Nov/2009:16:07:52 CONFIG INFO server.log_request_headers: False
09/Nov/2009:16:07:52 CONFIG INFO server.protocol_version: HTTP/1.0
09/Nov/2009:16:07:52 CONFIG INFO server.socket_host: localhost
09/Nov/2009:16:07:52 CONFIG INFO server.socket_port: 8080
09/Nov/2009:16:07:52 CONFIG INFO server.socket_file:
09/Nov/2009:16:07:52 CONFIG INFO server.reverse_dns: False
09/Nov/2009:16:07:52 CONFIG INFO server.socket_queue_size: 5
09/Nov/2009:16:07:52 CONFIG INFO server.thread_pool: 10
09/Nov/2009:16:07:52 HTTP INFO Serving HTTP on http://localhost:8080/
2009-11-09 16:07:52,790::INFO::Lauching browser with http://localhost:8080/sabnzbd
blackbox:~# /etc/init.d/sabnzbd start
Starting SABnzbd.
blackbox:~#
