lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
Docproc
Nov 19, 2009Aspirant
Another thing to be careful of - I installed SABnzbd in /root/src and was finding I was getting lots of "Disk full" errors when there were hundreds of Gb free.
I hadn't realised that the ReadyNAS has 2 partitions, the main data one which is as big as the drives you have in the machine (so hundreds of Gb in my case) and a smaller root partition which is only 2Gb, where the system software is installed.
My SABnzbd directory - including the potentially large cache/ and downloads/ directories - was in this small partition, hence the disk full errors.
The reason it was only intermittent was that there just happened to be enough space for SABnzbd to download and extract some of the small-ish files I was using, but when I tried a larger (1.5Gb) one, it hit the 2Gb limit.
So be careful about where your cache/ and download/ directories are - I've moved mine to /c/ now and it's working fine.
Just in case anyone's run into the same problem!
Glenn.
Glenn.
