lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
StarlightNo1
Apr 16, 2010Aspirant
I am trying to install it on the NVX for the last two days (linux n00b). I used the DUO guide and the posting of "gknippels" to get it to work: http://www.readynas.com/forum/viewtopic.php?f=61&t=33669&p=185834&hilit=SABNZBD+again#p185834
Unfortunately i cant get it to work because packages zlib1g-dev and libssl-dev will not install.
apt-get install zlib1g-dev
The following packages have unmet dependencies:
zlib1g-dev: Depends: zlib1g (= 1:1.2.3-13) but 1:1.2.3.3.dfsg-12 is to be installed
apt-get install libssl-dev
libssl-dev: Depends: libssl0.9.8 (= 0.9.8c-4etch4) but 0.9.8g-15+lenny3 is to be installed
Depends: zlib1g-dev but it is not going to be installed
Searching the internet for a guide to install Sabnzbd on the ReadyNAS NVX / PRO doesn't give any result. Also no add-in is (yet) available. Can someone provide us / me with a good guide or add-in to install Sabnzbd on the PRO?
