lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
WhoCares_
Oct 31, 2010Mentor
Well, that depends on the state of the 7-digits-payment negotiation ;)
And in earnest: getting it to work on the NV+ may be a bit harder than building the stuff for the Intel line. So I really don't know yet. Even if I made it work there, speeds will most likely be close to unbearable, especially for unpacking the downloaded stuff.
-Stefan
-Stefan
