lowfi
Aug 07, 2008Aspirant
[Super-Poussin] Sabnzbd request
Hi, Since hellanzb is not working could you give sab a try? http://www.sabnzbd.org/ Many thanks :)
hidefdog
Nov 01, 2010Aspirant
Stefan,
Thank you for this add-on. I had to rename both "/etc/default/sabnzbdplus.dpkg-new" and "/etc/init.d/sabnzbdplus.dpkg-new" to just be "sabnzbdplus"
I also did a "apt-get install python-pyopenssl" to get the ssl web interface and the ability to use ssl usenet servers working properly.
With those minor tweaks, it is working great now. Thanks again!
