pgalligan56
Feb 01, 2015Aspirant
Suspicious IP addresses open by ReadyNasRemote and ReadyOpen
I am using readynas remote and it is connecting to some strange ip addresses...
http://5.176.36.217.ipaddress.com/ will give u the info on one and...
http://5.202.53.50.ipaddress.com/ is the other
I have blocked access thru my windows 8.1 firewall but was curios if anyone else has seen this behavior?
Thanks
Patrick
Thanks
Patrick
- StephenBGuru - Experienced UserRemote uses the 5.x.x.x address space inside its VPN tunnels. It shouldn't, but it does.
So you aren't being hacked, you can take down your block. - pgalligan56AspirantWell isn't that special!
Thanks :D
