pgalligan56
Feb 01, 2015Aspirant
Suspicious IP addresses open by ReadyNasRemote and ReadyOpen
I am using readynas remote and it is connecting to some strange ip addresses... http://5.176.36.217.ipaddress.com/ will give u the info on one and... http://5.202.53.50.ipaddress.com/ is the othe...
Feb 01, 2015Guru - Experienced User
Remote uses the 5.x.x.x address space inside its VPN tunnels. It shouldn't, but it does.
So you aren't being hacked, you can take down your block.
