gicleonard
Dec 21, 2013Aspirant
Torrent Add-in
I have an NV+ that has been working perfectly for torrents for years now. I then added a duo to my network and now the torrents on the NV+ stopped working. I then saw that the torrent port on the D...
Dec 22, 2013Guru - Experienced User
If you did not manually forward the port in the router before, then the torrent client must have been requesting that the port be forwarded via upnp.
One solution is to manually forward the port in the router config to the NV+.
