Lennart_Myra
Feb 03, 2010Aspirant
Torrents Downloading but NOT Uploading...
Hello, I have a big problem with getting my NAS to work properly when it comes to torrents. When I use BitTorrent or Transmission I have no problems with downloading the torrents, but when it comes...
Seraph1
Feb 04, 2010Aspirant
Lennart_Myra wrote: I am not sure I got that part 100% right...
Local IP Adr - Start Port - End Port - Protocol - Enable
X - X - X - X - X
Local IP Adr: Your NAS' IP address.
Start port: 6881 (if you're using the built-in bittorrent client) or 51413 (if you're using the Transmission add-on)
End port: Same as above.
Protocol: TCP/UDP (or if you have to choose one of the two, choose TCP)
Enable: checked
Hope this helps.
