Lennart_Myra
Feb 03, 2010Aspirant
Torrents Downloading but NOT Uploading...
Hello, I have a big problem with getting my NAS to work properly when it comes to torrents. When I use BitTorrent or Transmission I have no problems with downloading the torrents, but when it comes...
Seraph1
Feb 04, 2010Aspirant
Is it a problem if nothing is uploading? eg. Are you not getting fast downloads because of it?
If you've done the forwarding correctly, there shouldn't be anything else getting in the way. I would suggest trying out the 1.90 beta that you can find here (if you are using a Duo or NV+):
http://www.readynas.com/contributed/sup ... 1Light.bin
