Lennart_Myra
Feb 04, 2010Aspirant
Torrents Downloading but NOT Uploading...
Hello,
I have a big problem with getting my NAS to work properly when it comes to torrents. When I use BitTorrent or Transmission I have no problems with downloading the torrents, but when it comes to uploading, nothing happens.
My download is usually maxed at 2,5mb/s, but uploading always stays at 0kb/s (sometimes it may go to like 5kb/s for a few seconds then back to 0 again)....What is the problem?
I am currently using a Cisco EPC2425 router which is connected to my Readynas Duo...
If additional info is required to solve it, please tell me....
Thanks!
/Lennart_Myra
Thanks!
/Lennart_Myra
- Seraph1AspirantIs it a problem if nothing is uploading? eg. Are you not getting fast downloads because of it?
If you've done the forwarding correctly, there shouldn't be anything else getting in the way. I would suggest trying out the 1.90 beta that you can find here (if you are using a Duo or NV+):
http://www.readynas.com/contributed/sup ... 1Light.bin - Lennart_MyraAspirantMy NAS received the ip 192.168.0.11 and I am using Transmission 1.83...it says something about tcp port 51413 in the preferences...
I tried forwarding that port and ip numbers, but still nothing is uploading...only downloading... - Seraph1AspirantOh... by the way, it should be noted that the bittorrent client on the NAS is not set to seed any of the files it downloads. It will only upload while you are downloading.
- Seraph1AspirantWhat IP did you set for your nas. It should be the internal IP (probably starting with 192.168 or 10.0).
What port did you set, and what bittorrent client are you using? - Lennart_MyraAspirantThank you for the quick answer! I have now tried it, but still nothing happens with my upload :(
Any other ideas? - Seraph1Aspirant
Lennart_Myra wrote: I am not sure I got that part 100% right...
Local IP Adr - Start Port - End Port - Protocol - Enable
X - X - X - X - X
Local IP Adr: Your NAS' IP address.
Start port: 6881 (if you're using the built-in bittorrent client) or 51413 (if you're using the Transmission add-on)
End port: Same as above.
Protocol: TCP/UDP (or if you have to choose one of the two, choose TCP)
Enable: checked
Hope this helps. - Lennart_MyraAspirantI am not sure I got that part 100% right...
It looks like this when I configure the router:
Setup
Advanced Settings - Port Forwarding
This page allows you to configure port forwarding for local IP addresses.
X - X - X - X - X
What exactly should I put in these cells?
(In my torrent client it says: network: incoming tcp port: 51413)
Thanks again! - Seraph1AspirantHave you forwarded the necessary port to your NAS on your router?
