MysteryMan1
Aug 08, 2010Aspirant
Transmission - Can I use it to upload/seed?
I have been using Transmission for a while now, to download torrent, and it works just fine. Now, I would like to upload/seed some video files I have on my hard disk to the www.TheBox.bz site. I ha...
MysteryMan1
Aug 09, 2010Aspirant
sdouek wrote: I believe what you are looking for is in the installed add ons underneath services in frontview.
Go to Transmission add-on and click create torrent.
make sure you use the proper tracker url.
This should work it works for me.
Having problems with demoniod.
Thanks - will give it a try later!!!!
