jamminontoast
Jan 27, 2012Aspirant
Transmission - No data found! use "Set Location" error
Hi all, i have an readynas Ultra6 and NVX, i've installed Transmission(v2.43.00) on both. It was really frustrating when Transmission kept on giving me Permission Denied errors. However looking ...
JarnoG
Jan 30, 2012Guide
If you change the folders in settings.json, then they already have to exist with the right permissions. I'm not sure if Transmission makes the folders if you change them from the web-interface.
To do so, close Transmission, make a share names "download" and make sure that the user "nobody" has read/write permissions
Then make the relevant folders (downloaded-, incomplete- and watch-folders).
Make sure the download-share and the folders have the right permissions by repeating the process in the post you mentioned.
Finally, set the correct folders in settings.json and start Transmission.
