jamminontoast
Jan 27, 2012Aspirant
Transmission - No data found! use "Set Location" error
Hi all, i have an readynas Ultra6 and NVX, i've installed Transmission(v2.43.00) on both. It was really frustrating when Transmission kept on giving me Permission Denied errors. However looking ...
JarnoG
Feb 09, 2012Guide
It is not an issue that you did not make that user yourself, they are internally used.
If the media share did not previously have that user and usergroup before, then you will have to check the checkbox before the option with "Set ownership and permission for existing files and folders in this share to the above settings" and press apply. Make sure that you have all the capital letters right as well, "/c/media" is different from "/c/Media"
