jamminontoast
Jan 27, 2012Aspirant
Transmission - No data found! use "Set Location" error
Hi all, i have an readynas Ultra6 and NVX, i've installed Transmission(v2.43.00) on both. It was really frustrating when Transmission kept on giving me Permission Denied errors. However looking ...
Lichon
Apr 25, 2012Aspirant
Changing share rights to fit an addon is NOT a solution! The old BitTorrent client could use whatever share rights you had, so Transmission needs to do so too.
Besides if I change share rights to nobody/nogroup, then I will NOT be able to administer my media share. Again, NOT a solution.
I had success when I creating the main folder and giving those nobody/nogroup rights for a few torrents, which works, but is a poor fix. For torrents that are files only, touch'ing the files and applying the same rights also works, even after they finish. I had to re-add the torrents which were giving errors, as "Verify data" does absolutely nothing once I got the "Set Location" error.
While this is essentially the same as JarnoGs fix, this only affects a few folders it is a "better" fix for me at the moment - even when work is required for each torrent added.
