jamminontoast
Jan 27, 2012Aspirant
Transmission - No data found! use "Set Location" error
Hi all, i have an readynas Ultra6 and NVX, i've installed Transmission(v2.43.00) on both. It was really frustrating when Transmission kept on giving me Permission Denied errors. However looking ...
JarnoG
Apr 26, 2012Guide
I agree that setting the permissions right only for the folders used by Transmission is the preferred option. However, it requires more work and I'm not sure how to do it from a Windows machine without sshing. (cifs doesn't support it properly I think and you can't change owner over ftp)
Setting the permissions for the whole share is an easy solution that has not given me any problems for the rest of the data on the share. An alternative method in between the two options would be to make a separate share for Transmission.
