leonardoborges
Aug 30, 2011Aspirant
Transmission 2.33 fails to connect to UDP trackers
Hi guys, I just got my self a ReadyNAS NV+ last week and been since then customizing it to my liking. It's running Radiator 4.1.7 and Transmission 2.33 But then I noticed that otherwise perfect ...
leonardoborges
Sep 11, 2011Aspirant
I should probably put the question out there in a different way: Is there anyone successfully using this add-on with the ReadyNAS and UDP trackers? It's pretty much useless without it.
