leonardoborges
Aug 30, 2011Aspirant
Transmission 2.33 fails to connect to UDP trackers
Hi guys, I just got my self a ReadyNAS NV+ last week and been since then customizing it to my liking. It's running Radiator 4.1.7 and Transmission 2.33 But then I noticed that otherwise perfect ...
Wurls80
Sep 20, 2011Aspirant
I'm having the same problem. Some downloads seem to work ok, others don't. I don't know if it's because some are using HTTP trackers and some aren't, but I upgraded so I could use UDP trackers and performance now is very patchy. Is downgrading the only way? Does 2.23 still support UDP trackers?
