leonardoborges
Aug 30, 2011Aspirant
Transmission 2.33 fails to connect to UDP trackers
Hi guys, I just got my self a ReadyNAS NV+ last week and been since then customizing it to my liking. It's running Radiator 4.1.7 and Transmission 2.33 But then I noticed that otherwise perfect ...
Wurls80
Sep 20, 2011Aspirant
I've spent the evening playing with this. I was running 2.32, now upgraded to 2.34b04 on a readynas duo running 4.1.7. I know it's not the latest firmware, but I'm loathed to upgrade it when I've got it running how I want. Well, nearly :-)
I made the error of uninstalling 2.32 before reinstalling 2.34, which meant I lost my settings file and so had to go about setting this up again. You'd think I'd remember, but again I've had to keep limiting the number of peers that can connect within transmission in order to keep the readynas on the network (if it's above a certain number - about 8 it appears - then the other computers on the network can't access it - either through frontview, or shares, or as networked drives - all I get is "Sorry, can't connect" errors. The only way I can get it back is to turn it off, unplug the router from the outside world, turn the duo back on, then access the transmission parameters, then plug the router back into the outside world and then hopefully find it all stays stable).
Anyway I did manage to download a whopping 2MB on one file (I'm just going one at a time), but the rest of the time I'm just getting "0 of 0 peers" connected and nothing happening. At least it's not the tracker not connected error I guess.
It's a shame because everything was running brilliantly with Transmission until I came across the need for UDP trackers.... I upgraded to 2.32 and got patchy success - time will tell what I have at the moment! If it doesn't work then I'll try downgrading to 2.23 if i can find the link.
