leonardoborges
Aug 30, 2011Aspirant
Transmission 2.33 fails to connect to UDP trackers
Hi guys, I just got my self a ReadyNAS NV+ last week and been since then customizing it to my liking. It's running Radiator 4.1.7 and Transmission 2.33 But then I noticed that otherwise perfect ...
benpoole
Sep 22, 2011Aspirant
I used to use Transmission happily on my NV+ until the new firmware betas to cope with OSX Lion. Now I can't get any version of Transmission to work—it simply won't connect to anything, although it reports that the port is open happily enough (daemon.log simply says that it can't connect to any of the trackers).
I tried running the latest beta but the web interface is b0rked in that version for me—anyone else seeing that? (Most of the buttons across the top of the screen are rendered as an un-styled HTML list, and can't be clicked).
I moved back down to 2.32 but still no joy connecting to anything. Transmission on my Mac (same network and connectivity) works just fine.
