leonardoborges
Aug 30, 2011Aspirant
Transmission 2.33 fails to connect to UDP trackers
Hi guys, I just got my self a ReadyNAS NV+ last week and been since then customizing it to my liking. It's running Radiator 4.1.7 and Transmission 2.33 But then I noticed that otherwise perfect ...
Wurls80
Sep 25, 2011Aspirant
Devilsrear
Thanks for posting, I'd be interested in your working set. After my last post I tried 2.34, and 2.32 again, but after changing parameters in the settings file they refused to restart. Looking at the forums found others with the same problem but no solution. It's odd because I've never had the problem before... So I got annoyed, removed transmission all together and put bittorrent back on. The Readynas stayed stable - until bittorrent tried to download something, when after a few minutes it disappeared off of the network - the precise reason why I moved to transmission in the first place. So removed that, and was waiting for someone to post a success story before I tried again! So thank you.....
