leonardoborges
Aug 30, 2011Aspirant
Transmission 2.33 fails to connect to UDP trackers
Hi guys, I just got my self a ReadyNAS NV+ last week and been since then customizing it to my liking. It's running Radiator 4.1.7 and Transmission 2.33 But then I noticed that otherwise perfect ...
MrAsker
Oct 12, 2011Tutor
I have basically the same issue as anyone else. Transmission used to work, now it doesn't. CPU Usage is high (~100%), no DL or UL, lots of message in the Recv-Q, etc ... I've upgraded and downgraded Transmission but no result. I've even bought a new Router (Netgear WNDR3800) to see if that helped but it didn't.
This is my netsstat output:
ODDJOB:~# netstat -ulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
udp 0 0 192.168.44.168:137 0.0.0.0:* 1600/nmbd
udp 0 0 0.0.0.0:137 0.0.0.0:* 1600/nmbd
udp 0 0 192.168.44.168:138 0.0.0.0:* 1600/nmbd
udp 0 0 0.0.0.0:138 0.0.0.0:* 1600/nmbd
udp 0 0 192.168.44.168:22081 0.0.0.0:* 1344/raidard
udp 0 0 0.0.0.0:22081 0.0.0.0:* 1344/raidard
udp 0 0 192.168.44.168:50001 0.0.0.0:* 1373/upnpd
udp 1048332 0 0.0.0.0:51413 0.0.0.0:* 20138/transmission-
udp 0 0 0.0.0.0:5353 0.0.0.0:* 1110/avahi-daemon:
udp 0 0 0.0.0.0:2666 0.0.0.0:* 20138/transmission-
udp 0 0 0.0.0.0:2667 0.0.0.0:* 20138/transmission-
udp 0 0 0.0.0.0:1900 0.0.0.0:* 1373/upnpd
udp 0 0 0.0.0.0:2669 0.0.0.0:* 20138/transmission-
udp 0 0 0.0.0.0:111 0.0.0.0:* 1053/portmap
I've tried different setting in the settings.json file but last time it worked I had the following setting:
"alt-speed-down": 20480,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 62,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 75,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": true,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 200,
"dht-enabled": true,
"download-dir": "/media/BitTorrent",
"download-queue-enabled": true,
"download-queue-size": 10,
"encryption": 1,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/media/BitTorrent/_Incomplete",
"incomplete-dir-enabled": true,
"lazy-bitfield-enabled": true,
"lpd-enabled": false,
"max-peers-global": 224,
"max-peers-per-torrent": 60,
"message-level": 2,
"open-file-limit": 32,
"peer-congestion-algorithm": "",
"peer-limit-global": 240,
"peer-limit-per-torrent": 50,
"peer-port": 51413,
"peer-port-random-enabled": 0,
"peer-port-random-high": 65000,
"peer-port-random-low": 48000,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 0,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": true,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{d15b146a3063b3ade7d0fecaa9602218a327a8c8gOoal64v",
"rpc-port": 8181,
"rpc-url": "/transmission/",
"rpc-username": "admin",
"rpc-whitelist": "*",
"rpc-whitelist-enabled": false,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "/c/addons-config/Transmission/email_alert",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 20480,
"speed-limit-down-enabled": false,
"speed-limit-up": 21,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 0,
"upload-slots-per-torrent": 10,
"utp-enabled": true,
"watch-dir": "/media/BitTorrent/_Sources/",
"watch-dir-enabled": true
One thing that I have noticed is that before I got problems I usually saw 2 transmission-da processes sharing the ~100% CPU Usage, now I only have one transmission-da process using all the CPU. It does not seem to matter how many concurrent peers I allow or the amount of active Torrents.
For more info: http://www.readynas.com/forum/viewtopic.php?f=36&t=57291
What I would like is to have some better way of getting logs from Transmission, does anybody have any idea on how to get this?
HELP!!! :)
"alt-speed-up": 75,
"encryption": 1,
"message-level": 2,
"peer-port": 51413,
"preallocation": 1,
"proxy": "",
"proxy-port": 80,
"proxy-type": 0,
"ratio-limit": 2,
"rpc-port": 8181,
"umask": 0,
HELP!!! :)
