leonardoborges
Aug 30, 2011Aspirant
Transmission 2.33 fails to connect to UDP trackers
Hi guys, I just got my self a ReadyNAS NV+ last week and been since then customizing it to my liking. It's running Radiator 4.1.7 and Transmission 2.33 But then I noticed that otherwise perfect ...
rodolphedj
Oct 27, 2011Aspirant
onryo wrote:
ObiWan84 wrote: I suspect that the issue is related to https://trac.transmissionbt.com/ticket/4556. Hopefully it will be fixed soon.
Thanks ObiWan,
You nailed this one and that explains why it is affecting the SPARC-based models (mine is an NV+). Looks like it was a pretty simple fix. Now we wait for the fix to get packaged and updated here. Thanks for posting.
Hi,
tested on readynas, and it is not solved.
http://www.readynas.com/forum/viewtopic.php?f=36&p=328290#p328290
