leonardoborges
Aug 30, 2011Aspirant
Transmission 2.33 fails to connect to UDP trackers
Hi guys,
I just got my self a ReadyNAS NV+ last week and been since then customizing it to my liking. It's running Radiator 4.1.7 and Transmission 2.33
But then I noticed that otherwise perfect torrents, would not even begin downloading on the NAS. As a test, I added the same torrent file to Transmission on my mac, and everything worked as expected.
Back to Transmission's web interface on the NAS, I opened the Inpection tab and saw this error on the failed torrent:
I searched the forums but couldn't find anything conclusive about it. Is there any sort of configuration on the ReadyNAS that needs to be done in order for UDP ports to work? Or is it a known issue for the Transmission add-on?
HTTP trackers works just fine.
Thanks
Announce error: Connection failed
Thanks
- Deaf_Raiders1AspirantI get error: Could not connect to tracker or any of them, brother has the same ReadyNAS Duo same stuff but he connects fine.
Any solution?
tried All transmission versions none of them seem to solve it.
