Aethylred
Sep 22, 2011Aspirant
Transmission 2.34b04 and RAIDiator 4.1.8 Crashes using UDP
Hi all, I've updated to RAIDiator 4.1.8 and Transmission 2.34b04, and it works... until I turn on the alternative bandwidth settings, which run from 8am to 2am (i.e. most of the day, but matches th...
Aethylred
Sep 23, 2011Aspirant
Ok, more crashing, but more information:
Will make those suggeted changes and see what happens.
[12:08:44.396] Found 1 blocklists in "/c/addons-config/Transmission/transmissio
n-daemon/blocklists" (session.c:2238)
[12:08:44.397] Transmission 2.33+ (12861) started (session.c:718)
[12:08:44.397] Cache Maximum cache size set to 1000.0 MiB (64000 blocks) (cache
.c:249)
[12:08:44.397] RPC Server Adding address to whitelist: * (rpc-server.c:805)
[12:08:44.397] RPC Server Serving RPC and Web requests on port 127.0.0.1:8181/transmission/ (rpc-server.c:999)
[12:08:44.397] RPC Server Whitelist enabled (rpc-server.c:1003)
[12:08:44.397] RPC Server Password required (rpc-server.c:1006)
[12:08:44.397] Bound socket 20 to port 51413 on 0.0.0.0 (net.c:373)
[12:08:44.397] UDP Failed to set receive buffer: requested 4194304, got 1048576 (tr-udp.c:75)
[12:08:44.397] UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:80)
[12:08:44.397] UDP Failed to set send buffer: requested 1048576, got 524288 (tr-udp.c:86)
[12:08:44.397] UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:91)
[12:08:44.398] DHT Initializing DHT (tr-dht.c:276)
