Aethylred
Sep 22, 2011Aspirant
Transmission 2.34b04 and RAIDiator 4.1.8 Crashes using UDP
Hi all, I've updated to RAIDiator 4.1.8 and Transmission 2.34b04, and it works... until I turn on the alternative bandwidth settings, which run from 8am to 2am (i.e. most of the day, but matches th...
Aethylred
Sep 24, 2011Aspirant
super-poussin wrote: Disable udp and let me know
Hmm, there's no item in settings.json or the command line options for disabling UDP, do you mean µTP (utp-enable in settings.json)?
I've checked the transmission wiki https://trac.transmissionbt.com/wiki/EditConfigFiles to be sure...
EDIT: I've checked the Transmission source https://trac.transmissionbt.com/browser ... smission.h and there does not seem to be an option for disabling UDP.
