Aethylred
Sep 22, 2011Aspirant
Transmission 2.34b04 and RAIDiator 4.1.8 Crashes using UDP
Hi all, I've updated to RAIDiator 4.1.8 and Transmission 2.34b04, and it works... until I turn on the alternative bandwidth settings, which run from 8am to 2am (i.e. most of the day, but matches th...
Aethylred
Sep 26, 2011Aspirant
Transmission no longer crashes, but the Web and Remote interfaces can not connect to the daemon. Transmission now uses a lot of CPU constantly, top shows it jumps between 60-98% available CPU, but memory is constant at about 5% (so it's not a memory leak).
Restarting transmission restores normal behavior while alt-bandwith is on (and set to 0kb/s) but any active downloding causes the interface to become unresponsive.
I've also discovered that shutting down transmission via the Frontview interface may not shut down all transmission-daemon threads, and often have to kill them from the command line to get a complete shutdown.
It also seems that although Transmission may be running, downloads are not progressing.
