Aethylred
Sep 22, 2011Aspirant
Transmission 2.34b04 and RAIDiator 4.1.8 Crashes using UDP
Hi all, I've updated to RAIDiator 4.1.8 and Transmission 2.34b04, and it works... until I turn on the alternative bandwidth settings, which run from 8am to 2am (i.e. most of the day, but matches th...
NASOO
Oct 09, 2011Aspirant
Let me know if you find the right version that is stable. I have a similar problem, but I arrived there with a different path. I havent tried to debug it like you are.
I had been away for a while and my NAS had remained unused (~4 months). So over the weekend I upgraded to the latest RAIDiator. This caused the Transmission to be unstable. I upgraded to the latest version (2.34b04) and have been downgrading ever since but to no avail.
The symptoms are that the ipaddress:8181 times out, or sometimes I get the UI, but it says it cannot connect. ps -A using ssh shows the transmission threads running. Turning it off and on via front view again solves the problem for about 5 minutes. Then it starts again.
I have reverted to the standard ReadyNAS BT client for the time period, but it doesn't support time shaping.
