Aethylred
Sep 22, 2011Aspirant
Transmission 2.34b04 and RAIDiator 4.1.8 Crashes using UDP
Hi all, I've updated to RAIDiator 4.1.8 and Transmission 2.34b04, and it works... until I turn on the alternative bandwidth settings, which run from 8am to 2am (i.e. most of the day, but matches th...
PatrikL
Oct 12, 2011Aspirant
I have the same problem with crashes as several have reported here. It seems like someone said before, that only some torrents cause this but I havent found the pattern yet. From browwing around the forum this seems pretty well spread, is there any work beeing done on this by the developer? Or is there a different torrent client which is known to be stable?
NASSOO mentioned reverting to the standard BT client. Can someone tell me how to do that on an Ultra? I havent been able to find any info about it (I had a Duo before so I know where it was on that)
