Aethylred
Sep 22, 2011Aspirant
Transmission 2.34b04 and RAIDiator 4.1.8 Crashes using UDP
Hi all, I've updated to RAIDiator 4.1.8 and Transmission 2.34b04, and it works... until I turn on the alternative bandwidth settings, which run from 8am to 2am (i.e. most of the day, but matches th...
Aethylred
Nov 02, 2011Aspirant
Transmission 2.42 is stable on the ReadyNAS Duo, it now stays up instead of crashing on errors connecting to UDP trackers, which is an improvement. I'll be jumping on the "Cannot connect to UDP" threads now.
