Aethylred
Sep 22, 2011Aspirant
Transmission 2.34b04 and RAIDiator 4.1.8 Crashes using UDP
Hi all, I've updated to RAIDiator 4.1.8 and Transmission 2.34b04, and it works... until I turn on the alternative bandwidth settings, which run from 8am to 2am (i.e. most of the day, but matches th...
baron888
May 18, 2012Aspirant
I also having the same problem with Transmission v2.42 on my new ReadyNAS-DUO v1 (Sparc version).
Transmission v2.42 just Kept stopping arbitrarily & freezing the transmission browser & stopped all downloads -- only a reset of Transmission from Front-View would restart it, but it would then just freeze up again! No idea what was causing it.
Ended up downgrading to v2.22 after long & helpful calls in to Netgear...Am monitoring v2.22 now, but so far so good & no freezes!...
Personally cant see much difference between the versions or in normal usability otherwise...Is Transmission v2.42 meant to be better at downloading than v2.22? I haven't noticed much difference & am enjoying less hassle & problems with the older version.
Regards
Baron.
Regards
Baron.
