nasaus1
May 25, 2012Aspirant
Transmission 2.42 ReadyNas Duo watch-dir fails
Hi All, tranmission back in version 2.16 watch-dir used to work in the settings.json file in all the versions to date it never ever works when i edit the file according to transmission and its ori...
JarnoG
Jun 01, 2012Guide
You will have to look for lines with "transmission-daemon" in it. You can try to put a (bunch of) torrents in the watch dir, wait a few minutes (to let Transmission do whatever it wants) and download the log then. That way you know the time you have to look for as well.
