nasaus1
May 25, 2012Aspirant
Transmission 2.42 ReadyNas Duo watch-dir fails
Hi All, tranmission back in version 2.16 watch-dir used to work in the settings.json file in all the versions to date it never ever works when i edit the file according to transmission and its ori...
JarnoG
Jun 01, 2012Guide
Remeber, these settings work for an Ultra 2 and are to heave for a Duo. Working settings for the Duo can be found here, but he has his watch dir off.
"alt-speed-down": 2500,
"alt-speed-enabled": true,
"alt-speed-time-begin": 510,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": true,
"alt-speed-time-end": 60,
"alt-speed-up": 300,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": true,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 64,
"dht-enabled": true,
"download-dir": "/c/media/BitTorrent/Downloaded",
"download-queue-enabled": true,
"download-queue-size": 10,
"encryption": 1,
"idle-seeding-limit": 5040,
"idle-seeding-limit-enabled": true,
"incomplete-dir": "/c/media/BitTorrent/Incomplete",
"incomplete-dir-enabled": true,
"lazy-bitfield-enabled": true,
"lpd-enabled": true,
"max-peers-global": 300,
"message-level": 1,
"open-file-limit": 64,
"peer-congestion-algorithm": "",
"peer-limit-global": 250,
"peer-limit-per-torrent": 50,
"peer-port": 51413,
"peer-port-random-enabled": 0,
"peer-port-random-high": 54999,
"peer-port-random-low": 45000,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"pidfile": "/var/run/transmission-daemon.pid",
"port-forwarding-enabled": true,
"preallocation": 2,
"prefetch-enabled": 1,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 5,
"ratio-limit-enabled": true,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "EnterYourPassword",
"rpc-port": 8181,
"rpc-url": "/transmission/",
"rpc-username": "EnterYourUsername",
"rpc-whitelist": "*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": true,
"script-torrent-done-filename": "/c/addons-config/Transmission/email_alert",
"seed-queue-enabled": false,
"seed-queue-size": 20,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 3000,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 0,
"upload-limit": 100,
"upload-limit-enabled": 0,
"upload-slots-per-torrent": 28,
"utp-enabled": true,
"watch-dir": "/c/media/BitTorrent/New",
"watch-dir-enabled": 1
