sendjes
Nov 25, 2012Aspirant
Transmission 2.42 save .torrent files
Hi. I was wondering, how to I make Transmission save .torrentfiles? This is my settings.json: { "alt-speed-down": 500, "alt-speed-enabled": true, "alt-speed-time-begin": 540...
HERBIEO
I dont know if this can be done but when you add a torrent it stores the torrent file in c/.transmissionbt/info/torrents
so you could allways copy them from there and save them somewhere before you remove the torrent,
i thought this line in the config ( "trash-original-torrent-files": false, ) would mean to keep the torrent files after you remove the torrent from the download list but it does not do that they get deleted when you remove the torrent.
