howsk
Jan 20, 2013Aspirant
Transmission 2.73 x86 file deselect problem?
Hi
Recently upgraded from my Sparc Duo to an Intel Pro 2 and installed latest Transmission 2.73.
I noticed that I was unable to de-select files within the Transmission Web Interface. This particular torrent had several folders and within each folder several files.
Firstly, deselecting a folder does not deselect the files within, and deselecting the individual files did not reduce the amount (or percentage) of torrent to download.
So, even when the individual files are de-selected, they continue to download. Tried on Safari running on MacOS and IE running on Windows 8 with Compatibility mode 10, 9 and 8.
Never had a problem with this on my Sparc Duo running Transmission 2.43.
In case it makes a difference:
My incomplete download location is the usual c/media/BitTorrent/Incomplete
My completed download location has been changed to c/Downloads
Anyone else experiencing this or know how to fix?
Thanks
Thanks
- ArafelAspirantIt was a known bug that was fixed in 2.75. The current version of transmission is 2.76 and super-poussin commented in another threat he hopes to have a new verison for readynas x86 out soon. I am eagerly awaiting that fix myself.
- gibxxiGuideIn the meantime try Transmission Remote for PC.
- howskAspirant@Arafel and gibxxi
Thanks for the info.
Looking forward to the next x86 release and will definitely try Transmission Remote in the meantime. - ArafelAspirant
gibxxi wrote: In the meantime try Transmission Remote for PC.
Thank you! I had a few torrents I was specifically waiting to download as I couldn't deselect the portions I didn't want.
