mission360's avatar
mission360
Transmission 2.76 Not Seeding
Just purchased for my Duo v2 and for the life in me I cannot get my torrents to seed. The port is confirmed as open, downloads without any issue, and plenty of leechers listed in the tracker. If I fire up Utorrent within my OS then I have no problem whatsoever seeding. Can anyone help before I get my money back for this software?
many thanks in advance!
  • Make sure you have UPNP enabled on your Router, it might need more ports open than just the regural one. UPNP will just open up ports as needed, to tell you the truth I dont know if Transmission uses UPNP, I know utorrent has the option to do that.
    Also another alternative is install Rutorrent and Rtorrent, First you would need to install RootSSH, if you mess up your system in the process of being inside of the linux CLI be warned it does void your warranty, but if you know your linux your set. There are plenty of guides online on how to setup Rutorrent and Rtorrent on a debian system.
    Or actually I just realized there is a 3rd party addon for it check it out:
    http://www.readynas.com/?p=6126
    But its only for sparc architecture so nevermind. However where there is a will there is a way. Research Rutorrent and rtorrent install on debian boxes and try it if you want to.
  • Thank you for the quick reply. UPNP is already switch on. I had such high hopes for Transmission on the ReadyNas, looks like it's back to the client running on the PC!
ProSupport for Business
