ssurba
Dec 19, 2012Guide
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
Hi Everyone,
this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on.
Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=390784
The latest version is 2.82-0.06.
Happy ReadyNASing! :D
Sergey.
Sergey.
- phpandsqlAspirantnot sure why, but all the settings e.g. speed limit and download directory do disappear every now and then, and it always goes back to the default.
- ssurbaGuideHi phpandsql, this problem should be fixed in latest version, please try it.
- cosmos1AspirantAwesome work, can't wait to try it at home mate!
- ashaniAspiranthello,
i am looking to enable web authentication on my transmission installation as i use port forwarding to access my web GUI remotely - cosmos1AspirantI have not done it, but guess the way to do it would be the following. First, enable SSH root access (see caveats about warranty though) on your netgear. Disable transmission from the web interface. Then ssh to the netgear box and edit the settings:
vi /transmission/settings.json
... to enable authentication as per https://forum.transmissionbt.com/viewto ... 362#p35883
Save the file and then re-enable transmission from the web interface. - ssurbaGuideHi ashani,
you can also edit settings.json without SSH, this file can be found \Transmission network share. Don't forget to restart Transmission after editing.
Sergey. - cosmos1Aspirant
Hehe, didn't think about that! :)
BTW, excellent build you gave us Sergey! I'm also using transmission-remote without any issue at all. Awesome :thumbsup: - super_poussinVirtuosodid you compile with --disable-nls --enable-lightweight --enable-largefile ?
- ssurbaGuide
super-poussin wrote: did you compile with --disable-nls --enable-lightweight --enable-largefile ?
Hi super-poussin,
I've compiled with --enable-lightweight only.
I did not want to disable NLS, because there could be files with national characters in names.
It seems that support for large files is enabled by default and as far as I know there is no option --enable-largefile in ./configure (as of v.2.77).
Regards, Sergey! - DcoreAspiranthi
and thanks for a grate addon, is there any whay to hide the transmission folder/share from som users or will it be included in a later release?
kind regards
