downunder11
Jul 07, 2014Aspirant
Transmission and VPN on a Readynas ?
Hi All, Firstly, I'm new to a NAS and very green so if you can help me please treat me like an technical newbie ! I purchased a ReadyNAS after owning x2 WD My Book Live's and losing ALL my data twi...
ChunkySocks
Aug 22, 2014Guide
I use a VPN connection from PIA - would really like my ReadyNAS to use the same connection / service that I use from my laptop but I can't seem to find any decent information around the internet as to whether it's possible. Most information / discussion I've read seems to be about setting the ReadyNAS up as a VPN server which isn't what I'm after - I want the ReadyNAS to connect to the internet via a VPN.
Other suggestions involve somehow setting up the home router to use the VPN connection (and by extension everything using the home LAN would use it too) but, again, have found a distinct lack of information / documentation, or at least, maybe information that involves technical expertise that I do not have. The router suggestion is further compounded because most routers that come from ISPs don't easily offer themselves up to configuration, if at all and the suggestion seems to involve forking out upwards of £80 for a new router that does.
If you got any further with finding answers with this, would really like to know. Thanks.
