humbleus
Aug 06, 2013Aspirant
Transmission Blocklist. Will it carry over to other Add-Ons?
I'm using an iblocklist list setup in Transmission. Will these ip filters/blocks work with other Add-ons, or does Transmission filter only within the Add-on? I wish to use ruTorrent for the time be...
humbleus
Aug 12, 2013Aspirant
That's unfortunate. I want to use rTorrent with WhoCare's adaptation of ruTorrent. How can I block using my iblocklist.com list? Help is much appreciated.
-edit: I would think if Transmission is open then it should block connections to the device and not just to the addon. Are you sure? If so, I could keep Transmission open while rTorrent is running.
