1600dave
Oct 30, 2013Aspirant
Transmission doesn't start when NAS starts up
When my NAS starts up each day at 7am, Transmission is always turned off, Plex starts on its own though. is there any way to make Transmission startup when the NAS turns on?
ReadyJabba
Oct 30, 2013Tutor
mesteele101 wrote: But how do you know if Transmission is not running?
When you try to connect via a client, when you select the app from the dashboard, when you type in the correct url for Transmission into your browser, it doesnt connect.
After you toggle the app switch off then on, they all connect.
