1600dave
Oct 30, 2013Aspirant
Transmission doesn't start when NAS starts up
When my NAS starts up each day at 7am, Transmission is always turned off, Plex starts on its own though.
is there any way to make Transmission startup when the NAS turns on?
- SimonRBAspirantRunning 6.1.6 on a RN102, just installed version 3.00.5 from poussin's dropbox, but still having the same issues with transmission failing to start when the nas starts.
- Could this be a problem with the OS, and not the program? Maybe that is why Poussin has not addressed the issue, But then again this could be a limit to his programming?
- btaroliProdigyI wouldn't dare to speculate... but I have several apps installed and this is the only one that exhibits this behavior. Others I use include PLEX, Automatic, DVBLink...
It's not impossible to imagine it could be an OS interaction, but it's not a system-wide behavior by any means. - Several months ago I bought into the ReadyNAS only to find these limitations. Unable to get Transmission to work properly, and unable to get a RSS feed to work using Automatic. I only had so long to try out the ReadyNAS and I was unable to get those two issues resolved. I returned the ReadyNAS, and bought into the Synology DS214Play. I have no problems with torrent downloads, RSS feeds, and using Plex. I mainly bought the NAS for Plex so the RSS feed and Plex was a must, and I am so pleased with the Synology DS214Play.
- btaroliProdigyThat's funny. I have zero problems with Automatic, but I guess experiences vary. Glad you're having success with Synology. Why still here? :)
- luk_slackwalkerAspirantHi,
I'm new at the forum and at the Readynas world...
Before to write here I've been looking around the forum for a while...with no luck...
Just bought a RN102 few weeks ago and I'm experiencing the same problem, when the RN102 reboots Transmission does not restart automatically; no error starting it manually.
Other story is aMule, installing it the first time it starts and works nice but after a reboot it does not start; trying to start it manually it rises the error: "Application failed to initialize" error 22002010000.
About aMule, also can not find any useful log about the error above in /data/amule/ nor in /home/admin/.amule (the folder does not exists, when the default script launches it as "admin").
Someone can help please?
Regards
Luk - giolodi1AspirantI have a Readynas 104 (fw 6.1.6) an the same problem with Transmission (3.00.3). I've seen several posts about thi issue. Is it possible nobody can give an answer?
Probably this app it's CAN'T start on nas startup. Hope there will be a new version which overtake the problem!
http://www.readynas.com/forum/viewtopic.php?f=22&t=75823 - +1
- +2 :worship:
- Desperation stakes...
http://www.readynas.com/forum/viewtopic.php?f=153&t=75867
