flowchart
Nov 20, 2009Aspirant
Transmission error ...
Transmission was working fine and now it wont connect .. when I go to my add ons, under transmission it has the message Please disable the add-on before modifying the /addons-config/Transmission/t...
dbott67
Nov 21, 2009Guide
Do you have another bittorrent client running?
You can also just try disabling the Transmission add-on to stop the service and then re-enabling it.
