flowchart
Nov 20, 2009Aspirant
Transmission error ...
Transmission was working fine and now it wont connect .. when I go to my add ons, under transmission it has the message Please disable the add-on before modifying the /addons-config/Transmission/t...
flowchart
Nov 21, 2009Aspirant
Also, when I click on "Transmission Interface" I get this message
403 forbidden
Unauthorized IP Address.
Either disable the IP address whitelist or add your address to it.
If you're editing settings.json, see the 'rpc-whitelist' and 'rpc-whitelist-enabled' entries.
If you're still using ACLs, use a whitelist instead. See the transmission-daemon manpage for details.
Any idea how to do this ?
403 forbidden
