flowchart
Nov 20, 2009Aspirant
Transmission error ...
Transmission was working fine and now it wont connect .. when I go to my add ons, under transmission it has the message Please disable the add-on before modifying the /addons-config/Transmission/t...
Mutley1
Dec 10, 2009Aspirant
I need a quick reply here people. The coffee's worn off and I'm in trouble.
Is it the same for windows as putting it in for a mac i.e. "/c/media/BitTorrent" to map the download in the preferences for transmission?
I have a Share called media and a folder in that called BiTorrent. Which is the destination. So is it the same?
What's the "c" part at the start for? or should that be my Readynas hostname where the "c" is ?
like this /readynashostname/media/BiTorrent?
Help, I'm real tired and my brain's shutting down.
