flowchart
Nov 20, 2009Aspirant
Transmission error ...
Transmission was working fine and now it wont connect .. when I go to my add ons, under transmission it has the message Please disable the add-on before modifying the /addons-config/Transmission/t...
dbott67
Dec 15, 2009Guide
The default is /c/media/BitTorrent. The path specified is local to the NAS:
- c is the default data volume on the ReadyNAS
- media is a shared folder
- BitTorrent is a folder in the media share
In your case, if you have a share called my_files and a subdirectory called incoming, the correct path would be:
/c/my_files/incoming
