flowchart
Nov 20, 2009Aspirant
Transmission error ...
Transmission was working fine and now it wont connect .. when I go to my add ons, under transmission it has the message Please disable the add-on before modifying the /addons-config/Transmission/t...
Mutley1
Dec 18, 2009Aspirant
Problems again
Hello people. Here goes again. I had 1.76 working. Had to mess around with the white list with the suggestions above. In fact my posts above state that. I then thought it would be a good idea to edit the white list to alter the download location, because the settings were not being retained in the preference box in the GUI. Eventually it stopped working. Couldn't download/upload anything, error message saying path not recognized. So I backed up the Transmission folder somewhere, uninstalled and tried to reinstall Transmission. Tried 1.76 and 1.77. Neither would then work for me. It kept asking me for the Readynas login deatails , username and password. I clicked and didn't clicked, but neither would work. I then pulled up the .Json settings for the old one I'd kept and the new one in the add ons transmission folder to compare.
Now going back on this post I'd followed Super-Poussins direction and it worked. But this time it was the same as the corrections that were the offered fix. i.e. below
What I did notice were that this was different this time "rpc-port": 9091,
Before it had always been 8181, but now last time it had took on 9091 as quoted above. I've tried to change it in the whitelist, but no use. Basically I've deleted/removed/rebooted Transmission and the Readynas about a dozen times now and can't get nothing to work. And now I turn to the Gods of the Readynas Forum.
Need your help here again people.
mutley
"rpc-whitelist": "*",
"rpc-whitelist-enabled": true,
mutley
