flowchart
Nov 20, 2009Aspirant
Transmission error ...
Transmission was working fine and now it wont connect .. when I go to my add ons, under transmission it has the message Please disable the add-on before modifying the /addons-config/Transmission/t...
super_poussin
Dec 18, 2009Virtuoso
please use other words !!!
the default config file is ok for a std use.
if you edit it please use a good editor like notepad++ and stop transmission before doing any change.
If you did not change your way of speaking it will be my last answer to your post
