flowchart
Nov 20, 2009Aspirant
Transmission error ...
Transmission was working fine and now it wont connect .. when I go to my add ons, under transmission it has the message Please disable the add-on before modifying the /addons-config/Transmission/t...
badbrad1
Jul 29, 2011Aspirant
Hi, new to the ReadyNas and transmission. Transmission has been working fine for a few months, but it suddenly started giving me the error message below and will not start/display. I've re-started Transmission several times to no effect. I tried to follow a similiar post about fixing this problem, but got lost! I cannot get into the /addons-config/Transmission/transmission-daemon/settings.json file. When I try to access either the "addons-config" subdirectory or the "webroot" directory on the ReadyNas, it keep asking for a password - but my normal password doesn't work. Really frustrated at this point - could someone help me out with this problem, please? Thanks.
403: Forbidden
Unauthorized IP Address.
Either disable the IP address whitelist or add your address to it.
If you're editing settings.json, see the 'rpc-whitelist' and 'rpc-whitelist-enabled' entries.
If you're still using ACLs, use a whitelist instead. See the transmission-daemon manpage for details.
403: Forbidden
